Baked grime on wheel weels
  • Baked grime on wheel weels
    Hi guys,
    Any recommended product for cleaning years of baked grime on aluminium alloy wells ?
    Off the self would be preferred if possible.
    Thanks,
    bowdens wheel cleaner, a clay bar and a lot of elbow grease!
      really without taking the wheels off ??
        nope only way is wheels off to do it properly
          Well then I want a lazy as I dont want to take wheels off. Suggestions ??
            Maybe consider a forum not dedicated to detailing?
              GOLD!
              Mick
              MY09 Senator Signature
              Cleaned --- Protected --- Driven
                Spot on there!
                Either do it properly or lower your expectations namz, can't have both.
                  Originally posted by EG30 View Post
                  Spot on there!
                  Its more abt skills, I dont know how to take off wheels and put them back on !
                    This should help... https://youtu.be/0kfJ7Lu4tvo
                    It's best to use a tourqe wrench to tighten the nuts up.
                    "Perfection is lots of little things done well." Fernand Point
                      You should really learn how to do this, important life skill.
                        I can and will definitely this, hopefully this weekend.
                        By the way are there any products to DIY fix scuff/scratches on alloys (mainly from kerbs etc) ?
                          Not affordably.
                          Wheels flex, and get very hot.
                          Most home repairs would be lucky to last a week.
                          From memory, The Touchup Guys would probably charge less for than $250 for a set of four wheels, and use all the appropriate fillers + paints to make sure the repair bonds permanently.
                          Depending on where you are, there is also a shop in Melbourne that does machined/welded repairs and then re-powder coat. The cost is a lot higher there, however.
                          • #14
                            Hi guys
                            What would be your go-to product to get the baked grime off?
                            I've seen Autosmart Tardis come up in a few search posts.
                            Would this be safe to use on darker colour alloys and factory painted brake callipers?
                            Sent from my iPad using Tapatalk
                            • #15
                              Using bowdens own wheely clean. Seems a good product so far.
